Sizing Hidden radiators
The Steam Whisperer (Formerly Boilerpro)
Member Posts: 834
I have a couple that the numbers just don't seem right. A 6 x27 horizontal duct feeds the radiator, the ductwork at the radiator is 36 x 32. The steam supply is 1 inch with a 3/4 inch Moline (orificed) supply valve. Using the cold flue size I come up with 162 EDR.....sounds like way too much. Any Ideas?
comparison
I have a couple that are about the same. Inlet duct on one is 5 x 32, the other is 6 x 30. From opening the boxes and measuring the sections and comparing to EDR of sun indirects in the library, I know that mine are 165 edr.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
Thanks.....
If they are actually 162 EDR @ 70 air temp, I would expect the output would be much higher if they are heating -10F outdoor air......something I suppose I need to watch out for.There was an error rendering this rich post.
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
