BAXI Luna 310 Fi
iceboater
Problem with my BAXI Luna 310 Fi. I use it for both hot water and radiant heat. I installed it myself about 10 years ago, replaced the PCB about 5 years ago. Here is the current problem: It will cycle for about 30 minutes fine, then it will overheat and not shut down even when the temp. goes up. I believe this is also called a failure to modulate? It will then blow off and shut down and gives a fault code of either 6 or 8. Sometimes it gives the pilot fault code and sometimes the fan. Thoughts?
Also how do you clean out the venturi and where is it located?
many thanks.
many thanks.
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
