Knocking... Sometimes...
Javelin
Member Posts: 160
Heating Pros,
Back in October, had a new Triangle Tube Prestige put in and it's great, but recently (since it has actually become colder out) not sure if it matters, I get a pretty regular knocking. Also installed a TT indirect tank, and the odd thing is that if I manually put on the DHW pump, the knocking goes away.. otherwise when the DHW pump it off, the knocking/rattling is there and is enough that it travels throughout the pipes throughout the house.
I've bled all the radiators - no more air coming out, and the system has (what I think to be) a properly installed spirovent that should eliminate any air bubbles I would think. Just odd that it only is silent when the DHW pump is ON, and like I said, wasn't a problem a month ago.
Does anyone have any thoughts? All the radiators DO seem to be getting plenty hot as needed and the house is toasty - just a bit noise. I've attached a couple pictures of the setup and a video with the noise is available at:
<a href="https://www.icloud.com/photostream/#A25oqs3qorqf9">https://www.icloud.com/photostream/#A25oqs3qorqf9</a>
Check valve
It sounds like the check valve is chattering. It is a swing check and should be a spring check. You are also missing a spring check on the boiler return line. Call you installer and have him fix those check valves and you should be okay.
Rob0 -
Thanks!
Thank you Rob G! I'll replace the "swing" with a "spring". The system does have a check valve on the return already, but it's just out of the photo to the left.
Thanks again,
Jay0 -
check valve
There needs to be a check valve on the boiler loop going to the house system and one on the loo going to the indirect water heater.0
- 87.5K THE MAIN WALL
- 118 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
