Steam Pro in Westchester County, NY
Mark_125
Member Posts: 56
Hi All,
After striking out with 3 'heating' experts who are 'familiar with steam' I need to know if anybody has found a good steam guy licensed in Westchester County, NY.
I have tried the find a contractor and they come back with contacts who are located in the Bronx, Brooklyn or NJ. Unless you are licensed in Westchester, you can't do work in Westchester.
Thanks,
Mark
Thanks,
Mark
would you mind describing the heating issue
you are facing?0 -
Issues
I am currently living with
1. Oversized, aging boiler
2. resulting in high fuel bills
3. improper near boiler piping
4. resulting in wet steam
5. whistling air vents
6. overheating
I have a 1200sqft colonial thats heated by steam with a 300sqft addition heated by hot water. September to April usage is about 1000 therms.
Steam is produced so quickly that all of my vents whistle the longer the cycle goes on, I have set my pressuretrol as low as it will go.
I have balanced the system the best I can, but as it gets colder, the cycles last longer and the bedrooms get warmer so I have to go around and change out the valves for slower ones. I am considering some TRVs that might address that.
I have my Honeywell thermostat set for 2CPH0 -
Get the book
You can take a whack at it yourself by buying a couple of dans books. First you need the EDR book which will tell you if your boiler is sized for the amount of radiation in the home. Now if the rads are oversized, there are a few little tricks that can be done to cut back on the amount of heat output they produce (however, this will not change the square feet of radiation which is what you will use to size your boiler correctly). Once you got that squared away, you can tackle other things such as boiler piping, venting and pressure setting. Good luck and were here to help.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 5.7K Gas Heating
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 6.3K Radiant Heating
- 393 Solar
- 15.4K Strictly Steam
- 55 Water Quality
- 46 Industry Classes
- 49 Job Opportunities
