water loop bypass
Mannu
Mannu Member Posts: 21
A: The flow in gallons per minute isn't crucial here. Just keep your eye on the thermometer on the line supplying the zone. Stop blending when it reaches 180 degrees F. Then, take the handle off the ball valve so no one else can mess with it. This will be the hottest water the zone will ever see.
So i totally understand the process, the aquastat i'm using (L4006A) doesnt tell you temperature it only has the temperature setting. So how do i know when the temperature hits 180 degrees? do i need to install a temperature guage on the pipe?
