New system monitoring, guages, etc
Robert_H
Member Posts: 135
What do you like us see installed in a systems plumbing for monitoring; temp sensors pressure gauges etc.?
The system is a Mod con feeding mostly cast rads with one radiant ceiling.
Pri/Sec with as system manifold on the secondary loop that feeds each rad (home run) and also feeds the ceiling manifold.
The Ceiling manifold has supply and return temp gauges and flow meters.
The sec circulator is Bumble Bee and it can monitor GPM
Robert
Robert
How much info
Do you want, and how accurate? At the very least system pressure. Most mod cons have a lot of info available fro the control temperatures, fan speed, etc,.
Don't put too much faith I those pump gpm readings, regardless of the brand. When measured against lab quality certified meters errors of 40% were recorded
Temperature gauges on mixed temperature zones can be handy for commissioning and troubleshooting. Same with flow meters on the loops.Bob "hot rod" Rohr
Living the hydronic dream0 -
Thanks Hotrod
I want to make sure I have the sensors necessary to do any system troubleshooting if there is a failure. Also if the design needs any tweaks, we can get the information from the system.
a system preasure guage sound like a good idea.0
- 121.3K All Categories
- 84K THE MAIN WALL
- 2.9K A-C, Heat Pumps & Refrigeration
- 53 Biomass
- 417 Carbon Monoxide Awareness
- 40 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.7K Gas Heating
- 119 Geothermal
- 155 Indoor-Air Quality
- 3K Oil Heating
- 56 Pipe Deterioration
- 769 Plumbing
- 5.4K Radiant Heating
- 362 Solar
- 14K Strictly Steam
- 3K Thermostats and Controls
- 51 Water Quality
- 38 Industry Classes
- 73 Job Opportunities
