Giannoni Heat Exchanger Surface Area
JJS
Member Posts: 3
in Gas Heating
Anyone out there aware of the different surface areas that boiler manufacturers use in their Giannoni exchangers? I have noticed recently it looks like one manufacturer in particular seems to over fire their boiler to the rating I see on the ASME stamp of the exchanger -- not sure if all the manufacturers do or not.
The one in question says the rating is simply a minimum relief valve capacity - not a firing capacity. Oddly enough I have had quite a few exchangers burn out of these boilers -- not a lot of experience however in others.
Any one have info on...
Hamilton Engineering
Laars
Heat Transfer - Munchkin
Lochinvar
Trinity's
Viessmann (although not Giannoni but similar design)
Looking for a simple BTU input per sqft surface area
Laars
Lochinvar
Trinity's
- 128 Chimneys & Flues
