Angle for clanking noise
TkNeo
Member Posts: 1
Hi, I have a fourplex with steam radiators and tenants are hearing ton of clanking noise. I have read up quite a bit to learn that it could be from the condensed steam as the radiators are definitely not tilted towards the input valve/pipe. I am going to shim the other end using furniture pads or wood etc but i am not sure what angle is needed ? Somewhere i read that the angle should be 5 degrees. So, for my 3 feet long radiator, I need to use a shim thats around 3 inches. That sounded too much so i thought i will check here to see what others think.
This is a great forum with tons of knowledge and its my first post here ! Thanks in advance.
Angle
I'm not a pro but I can share my own experiences on my 1 pipe system.
I have quite a few 20+ section radiators and most of them are level, not tilted at all. One of them is tilted away from the pipe as are a few of my smaller ones. To get them right I would need around half inch shims, not too much.
None of them make any noise. I had started shimming them until I realized it probably didn't matter. Water lays in the bottom of the radiator most of the time anyway due to how its made and they are often piped with a bushing on the inlet.
What matters is that water doesn't impede the flow of steam at all. When that happens its very bad. I had a 10 foot runout to a radiator that was not pitched. It banged horribly. I raised it up very little and it works perfectly.
If you have heard the actual radiators hammer, I would try shimming them as much as you can without it looking ridicules or putting a lot of stress on the pipe and see what happens.
If you can provide some pictures just to give an overall idea of things that will help as well.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
- 120 Geothermal
- 394 Solar
