recessed convector but not Solray
MIKE3.5
Member Posts: 9
Does anyone kow what this is? I'm trying to size a boiler. It is just a front tube and hollow behind with a tin back about 3" deep and has tin sides. It's on a steam system. The square hole has a matching panel to fit in it. The hole allows the access to the steam vent just to it's left inside the hollow tin cavity. The manifold is accross the bottom. I cant tell if there are push nipples between tube but I think not. The overal height is 24". There are 8 in the house with all different widths.
Not a W-M Raydiant either
but it's very similar. You could probably use those ratings if you can't find anything closer.Just another DIYer | King of Prussia, PA
1983(?) Peerless G-561-W-S | 3" drop header, CG400-1090, VXT-240
- 120 Geothermal
- 394 Solar
