Rain in the Sight Glass
Steam_Starter
Member Posts: 109
All,
Hello. As you probably have noticed from my earlier posts, I finally installed my 3" drop header. Thanks to guys like Steamhead, JStar, Rod and everyone else, I was able to pretty much get it right (I think...)
Nonetheless, I have been skimming for a while and I am still getting rain int he sight glass. It is lessening now but with all of the oil that is / was in the system I am sure that this is a direct cause for the rain. Am I making a correct assumption?
There is very little surging as the waterline barely fluctuates during steaming...I just want to make sure I have to keep skimming / flushing.
Thanks all!
JLG
Thanks all!
JLG
"Hey, it looks good on you though..."
Still have oil in there
You will have to keep skimming to get rid of that oil, cleaning the system out with a wand would get the crud out of the boiler but can't get to the piping if thats where the oil is coming from. Some boiler makers advise using washing soda in the boiler to clean things out.
3PSI gauge0 -
Thanks BobC!
I was thinking that was it. I cleaned the piping and the fittings best I could before install but there was a lot of cutting oil residue I just couldn't get out of the pipes.
Ill keep skimming and flushing away!
Have a good one!"Hey, it looks good on you though..."0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
