Taco Bumblebee Buzzes-
ced48
Member Posts: 469
Contrary to what the folks at Taco claim the origin of this little circulators name to be, I have to believe it really comes from the sounds it omits. The little guy buzzes. I have only lived with him for a day or so, so I can't tell whether we will adjust to each other, or not. He operates out of a closet in my den, where I spend my evenings. Otherwise, I wouldn't give the buzz a second thought. Seriously, I think I will adjust to the sound quite quickly, especially if he does his job well. If not, there will be an orphaned bee up for adoption.
But why?
Other Taco circs are noise free, as are other ECM brands. To the point you need a spin-dictator to tell if they are powered or spinning. Engineer the buzz away
Living the hydronic dream0 -
Yeah, I Just Might-
give Taco a call, being a rhode Islander, I could bring their bee back home to them, i'll see-0 -
how did
the rest of the system go? Have you had the baseboard running yet?0 -
YUP!
I just posted this same thing a week or so ago, got very little feed back from the wallies but my customers hate the buzz. I may even need to go swap it for a less noisy, less efficient and less smart pump. I received an email that someone from Taco would be calling me but got nothing. The thinking behind these pumps is pretty superb but the noise will haunt installers if the system is anywhere near the living space.Tom
Montpelier Vt0 -
Reverberations
Is piping isolated from structure?
It does not take much to reverberate velocity noise, or circ noise.0 -
Gordy
I know what you are saying I had a nice injection pump give me noise a while back from tight hangers and too close to the wall. This buzz is very different, I will try to record the noise next time I am there. Oh by the way Taco has contacted me to try to work out a solution. Will update you allTom
Montpelier Vt0 -
In what mode
Are you both running the bee?
Just wondering if both of you are using same setting, or have tried different modes, or constant speeds ?0 -
Modes
All the bumble bees I have installed are in the delta T mode. The noise is much worse the higher the circ runs. Still noisy though in any speed.Tom
Montpelier Vt0 -
Yes, System Is Up and Running-
At this point, it seems fantastic- All my concerns about the boiler being oversized are gone. With the outdoor setback, the boiler modulates itself down to 20 to 30 percent, and just hums right along. Still have some fine tuning to do, like what to do with the Bumblebee, but it should be just fine, Could not be happier. Again, thanks to all who have helped-
The noise from the Bee is not vibration, it's his motor or control. Faster it runs, the more it buzzes. I too am waiting for a call from Taco.0 -
Noisy Bumble Bee
Please contact me at stetho@taco-hvac.com or 401-441-2934.
I'll hook you up with our B Bee Product Manager and engineering team to look into the noise issue.0 -
Just Spoke With
Steve at Taco- confirmed that the Bee does have more noise than they would like-made some suggestions for a replacement. I will most likely go with another pump. Taco has offered to work with me on the replacement. I would rate their customer support as excellent-0
- 129 Chimneys & Flues
- 122 Geothermal
