conversion burners
rick in Alaska
Member Posts: 1,526
in Gas Heating
HI guys and gals!
I am sure I have asked this before but never go a clear answer on it.
When doing a conversion on a furnace or boiler and the conversion burner manufacturer has not tried their burner on whatever it is that you are converting, how do you decide to use it or not.
I trying to find out if I use say a Riello burner on a furnace that used an Af11 burner, even though the manufacturer says they haven't tested it on this furnace, who is liable? I am fairly sure it is me, but wanting to verify. I am not wanting to do anything that makes me liable for using a product that hasn't been tested by the manufacturer.
So I guess basically my question is this: If I have a furnace and I want to convert it, which way should I go. Go for the best assumed burner, or replace it. At this time, I am replacing them as I feel it is cheaper anyway. But I do have a couple of Williamson and Thermopride furnaces that I know have a lot of life left in them and are also in a bad place to get to for removal, and it would be nice to just change the burner.
I also have a church with 7 lennox furnaces that were installed back in '07. Convert or replace?
Thanks for any help or advice. Much appreciated.
Rick
I
Rick
I
- 128 Chimneys & Flues
