Cold Draft
Andrew boiler
Member Posts: 44
My thermostat is at set for 68 it says 69 also there a cold draft in my master bed room.
Should I turn up the heat?
Window
First I would close the bedroom window. If that didn't work then I would try to stop the draft.0
- 129 Chimneys & Flues
- 122 Geothermal
