Dead Men's Steam School
Hi. Who is the intended audience for the Dead Men's Steam School? Are homeowners welcome or is it intended for professionals? I have a one-pipe system that needs some help. I have one of Dan's books on its way, but I'm wondering if my best bet is attending the upcoming seminar in Massachusetts.
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,634
    We often have homeowners at that one.
    If you're a visual thinker you'll get a lot out of it. Thanks.
    Retired and loving it.
  • Dave in QCA
    Dave in QCA Member Posts: 1,803
    You should go!
    A few weeks ago I attended the one in Davenport, Iowa. I am not a contractor or installer, but I own a building that has needed a lot of attention to get the old steam system working correctly. Although I have had a career in facilities management and historic preservation, which included operating a large institutional high pressure steam system, I have found that my previous knowledge of steam did not help me at all when it came to the operation of residential type steam systems.
    Dan is not only a great presenter, he's a nice guy too! You'll be glad you went!
    Dave in Quad Cities, America
    http://grandviewdavenport.com
