Would you call this a Tube type radiator?
I'm going to try and calculate EDR. Based on the documentation I am using, I have a few radiators that don't seem to match any of the ones in the diagrams. Closest seems to be tube type. I can lift off the top...as seen in the photo. What do you think?
Thank you.
Isabella
  • JStar
    JStar Member Posts: 2,752
    Radiator
    https://patentimages.storage.googleapis.com/pdfs/US1868743.pdf
    Check out this original patent for a C.W. Good radiator. That's the only information I've ever found on this style radiator. Still looking for ratings. In the meantime, what are the physical dimensions?
  • Isabella
    Isabella Member Posts: 17
    Dimensions
    So far, I only have two sizes measured.
    One is in a room that is 11 1/2' x 9' and the dimensions are:
    24" h x 27" w x 5" d
    Second room is 13' x 12' (there is a hallway and closet I didn't include in the measurement), two radiators and the dimensions are:
    24" h x 32" w x 5" d
    I have a more rooms to measure and some have the same style radiator that are deeper (when you look inside, there are two rows). Then there are a smattering of more traditional radiators as well. 28 radiators total, 19 are this style.
    Thank you.
    Steamhead Member Posts: 18,500
    I think
    Weil-McLain made that, and it's called Raydiant.
    Consulting
  • Isabella
    And now that I know what I'm looking for...
    It's right on the side, RAYDIANT PAT'D WEIL McLAIN ERIE PA
    Thank you.
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    RATINGS
    The Raydiant 5" freestanding cabinet radiator is on page 175 of Dan's EDR book.
    For the two you have listed, they are as follows:
    5" Deep x 27 1/8" wide x 23" tall = 22.25 EDR
    5" Deep x 31 7/8" wide x 23" tall = 25.75 EDR
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • Isabella
    Incredibly helpful information
    Dan,
    Thank you, that is great. Is it in poor taste to add a few more sizes?
    5" d x 20 1/8" h x 22 1/8" w
    5" d x 20 1/8 h x 27" w
    5" d x 23" h x 37" w
    8 1/2" d x 23" h x 32" w
    8 1/2" d x 23" h x 41 1/2" w (fondly referred to as 'beast')
    Again, thank you.
    Isabella
  • Dave in QCA
    At your service
    Here are the ratings:
    5" d x 20 1/8" h x 22 1/8" w 16 1/2 sq ft
    5" d x 20 1/8 h x 27" w 19 1/2 sq ft
    5" d x 23" h x 37" w 29 sq ft
    8 1/2" d x 23" h x 32" w 34 sq ft
    8 1/2" d x 23" h x 41 1/2" w (fondly referred to as 'beast') 43 sqft
  • Isabella
    Thank you
    I'm very grateful.
    Now just to tackle the radiators in the garage. They don't seem to follow any of the illustrations I have either. I will get some photos and ask more questions tomorrow.
    I've almost got it all calculated.
