Laars Minitherm JVS banging/knocking
theStudent
Member Posts: 2
Hi,
Have 4 years old Laars Minitherm JVS boiler. recently it started to make banging/knocking sounds. It starts, works for about 15 minutes, temperature goes to about 165-170 degrees, then knocking/banging starts, I see pressure spike on pressure gauge and water spill through spirovent (it is on primary loop) occurs. Primary loop circulator was replaced by a plumber, but it did not help. Any thoughts? Thank you.
a flow issue
Is it the correct size pump? Air purged out? Could be the HX is plugging up inside the tubes, it may need a chemical flush. Measure the temperature rise from supply to return.Bob "hot rod" Rohr
Living the hydronic dream0 -
Thank you
Thank you, you were right. Yesterday we checked everything and it appears that the problem was with primary circulator loose wire. So far it works fine. Thank you very much again.0 -
Thanks for the update
It's nice to see the final result of the advice given here!--NBC0
