broken cap on steam valves
Dsisson
Member Posts: 116
Hi guys,
I have 2 leaky steam valves. These are right angle valves. the cap on the top (where the handle goes into the valve) is broken - the brass compression nut has spit the top off, letting steam and water into the room.
Where the heck do I find new brass compression caps? These seem to have a 1/2" flare thread. See the image - for the part I'm looking for. Other than these broken caps, the valves are fine.
valve
If you can find the same brand valve you can loosen the bonnet on the old valve, remove the disc and stem assy. and replace it with disc stem and handle from new valve. Or just replace the valve. I dont recommend this as a homeowner type jobThere was an error rendering this rich post.
- 120 Geothermal
- 394 Solar
