forced air to hot water
adam9367
Hello, I’m a DIY’r and I’m doing a complete remodel of my house. I want to switch from forced air to hot water heat and I have a minimal amount of heating experience. However, I have a good working knowledge of plumbing and electric.
I have a two story, 3600 sq. foot house (1800 sq. ft) on each level. The first floor is sitting on a 4” concrete slab with the back half of the first floor under ground. The second floor is 2x4 construction with 3.5” insulation. Before buying all of the parts/boiler I was hoping I could get the opinion of a few professionals to make sure I have a good game plan. I attached some drawings to make the discussion easier.
My plan is to use a combination of Buderus radiators and Ultra-fin in floor heating (180 degree layout). I would like to have five zones: zone 1 for indirect water heat, zone 2 for the first floor, zone 3 for the second floor, zone 4 for the in-floor heat for the first bathroom and zone 5 for the in-floor heat for the second bathroom. For each radiator in zone 2 and zone 3 I plan on using ½ pex with home runs to the zone manifold. So here are my questions and thanks for the help in advance.
1. I used the slant-fin btu calculator to determine that my house needs 79,000 BTU; 56,000 for the first floor and 23,000 for the second floor. Does that seem reasonable that I could heat a 3600 sq ft. house with only 80,000 BTU?
2. I’m trying to determine if I should go with a high efficiency boiler or cast iron. Can someone please share pros/cons other than the obvious cost savings?
3. Can someone recommend a particular boiler? I have only used weil-mclain in the past (which I liked)
4. If I buy radiators that are rated for more BTU than the room calls for (aesthetic purposes) can I use thermostatic radiator valves on each of the radiators for regulating temperatures?
5. Would you recommend using a single circulator pump and zone valves or circulating pumps on each zone in place of zone valves?
Ultra Fin
Do not use it , you will be making a HUGE mistake . Suspended tube systems are for interior areas that need very little heat ,SOMETIMES. The idea of Buderus Panel rads with TRVs is a good one , why not use them everywhere ? Only the areas that require heat will get it , you will be extensively zoned without wires , and you will save a ton of fuel money . I would run them all as homeruns from a central manifold and use a variable speed ECM circ capable of handling the volume and pressure required if they are all calling at once , unlikely . As far as boilers go , there are many good ones out there . If you want to use a condensing boiler you will have to upsize the Panel rads a bit to insure the High efficiency boiler is getting low enough return water temps for you to receive the rated efficiencies for a good portion of time every year . I would be inclined if budget is a constraint to go with an 85% boiler , a 3 way Taco I series mixing valve with outdoor reset and boiler protection and sit back and enjoy the comfort and savings . Just my .02 .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
I like the idea of using the standard cast iron boiler but I wouldn't know how to configure the mixing valve with the outdoor reset/boiler protection. I heard they can be very trick to configure correctly. Do you offer consulting?
I wanted to use the ultra-fin to warm the ceramic tile floor. (I hate walking on a cold floor.) I was also going to install a radiator to supplement if the in-floor wasn't sufficient.
How would I determine how big of a circulator I need for the zoned manifolds?
Thanks for the feedback!0 -
Ultra Fin
is not the way to go . Please tell me the exact situation you are looking at and how you intend to install the Ultra Fin and maybe we can tell you about better alternatives .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
- 133 Chimneys & Flues
