Munchkin T80M Boiler [ 2004 ] exhaust leak
gmoose
Member Posts: 6
Hi It has come to my attention that Munchkin had a rear exhaust leak problem in some of there [ 2004 ] T50M and T80M boilers and in fact have replaced some, Any info on this would be greatly appreciated. thanks, Gary
leak
Yes that is true.
Every time I have run across it HTP has replaced the boiler at no cost. Cost to install will be up to the homeowner.0 -
leak
Steve, thanks for the reply, would I contact the factory or the distributor if I have one of those boilers with that problem, thanks0 -
co"2 level
I'm getting co,2 readings from 32-80 inside my Munchkin T80M on the rear of the heat exchanger, could this level damage blower or controls, thanks for any input.0 -
Munchkin exhaust leak
It's my understanding that any CO reading above O inside the cabinet of a T80m would destroy the blower motor with corrosion, would that be a correct assumption,thanks0 -
leak
call the distributor - they will tell you the name of a qualified servicer. That servicer will get you the new boiler. Any leakage is bad and will destroy the blower and the 925 control.0 -
Munchkin T50M exhaust leak
Steve, thanks for the reply0 -
Munchkin service tech
Unfortunately HTP [ Munchkin ] can not come up with a service tech in my area Hamilton and Missoula, Mt [ Population over 80,000 ] and dozens of Heating contractors. When I asked the local Munchkin parts wholesaler in Missoula for a reference for a service tech to work on Munchkins, the reply was, everyone. Well we all know that's not true. Any help would be appreciated.Thanks0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
