Zone Valve End Switch question
Junkbox
Junkbox Member Posts: 7
I have a Honeywell 8043G zone valve and I want to create a dump zone on my wood boiler with it. My question is can I use the end switch the red wires to activate a separate circulating pump for that zone. I would like to take the 120volt hot and tie it to one red wire on the zone valve and the other red wire tied to the 120 volt feed to the pump. My goal is when the zone valve opens to turn the pump on. I just don't know if the end switch is rated for 120Volts.
  • SWEI
    SWEI Member Posts: 7,348
    Answer
    posted in controls section.  Please try to pick one forum when you post.
