Vacuum boiler
Peteys
Member Posts: 79
When you vacuum a boiler wouldn't you get a better clean by spraying out the sections with water? This is assuming you covered the chamber floor with plastic.
Boiler
I've done it in extreme cases. Very messy. I would rather try to sweep it dry first.0
