GV-3 Series 1 boiler issue
Chris49601
Member Posts: 1
I have a GV-3 Series 1 bolier that will not continue to run very long after it ignites. It goes through the normal cylce and ignites and will run for up to 5 minuts of so and then the gas valve begin clicking loudly. It will click once to several times and then shut down and restart the purge cycle. I have tried to troubleshoot it myself and have not found anything that is causing it. I did notice that if I tap the pressuer valve is will cause the valve to click and shut down. I replaced the pressure switch with a new one and that resulted in the boiler shuting down immediately after ignition, so I put the old one back on. I am trying to find someone in my area to look at but have not found anyone good yet I suspect the valve but do not want to spend $300 on my limited knowledge. Any help or suggestions woudl be appreciated. Thanks
- 114 Geothermal
