Your thoughts on using.....
PDB2
Member Posts: 26
1 1/2" pump flanges face to face with flat gaskets instead of unions or threaded fittings. I am building a different manifold setup on my near boiler piping and the thought occurred as an easier and more serviceable connection. Regular 4 bolt flanges would seem a little overkill and spendy...I already have the extra pump flanges, just wondering if the flat gasket are as dependable as a groove o-ring seal like on pump mounts.
I've never seen an example of this being done and am hoping some of you can gently explain why :)
I would think
It would make a weak connection. It's a more solid connection with the pump side backing up the flange fitting. Bolting two together as you describe would not be as solid as a 4 bolt style.0
- 117.6K All Categories
- 82.8K THE MAIN WALL
- 2.7K A-C, Heat Pumps & Refrigeration
- 43 Biomass
- 403 Carbon Monoxide Awareness
- 8 Chimneys & Flues
- 1.6K Domestic Hot Water
- 4.3K Gas Heating
- 107 Geothermal
- 148 Indoor-Air Quality
- 2.7K Oil Heating
- 45 Pipe Deterioration
- 681 Plumbing
- 4.8K Radiant Heating
- 353 Solar
- 13.3K Strictly Steam
- 2.9K Thermostats and Controls
- 48 Water Quality
- 31 Industry Classes
- 65 Job Opportunities
- 12 Recall Announcements
