Old ARCO Convector Radiator
Nickname
Member Posts: 2
Can any one identify this Steam Radiator. Looks like a cross between a Recessed Peerless Wall, Angled, and with Fins and a Sun-Rad! I would like to find the Net sq.ft.per section
The one pictured has 23 sections and the Cast Iron is about 16" H x 3½"D It appears to be a Standard ARCO Cabinet that is 26"H x 48"L x 4¾D
That's a cast-iron convector
you can find the ratings here, in the Library:
http://www.heatinghelp.com/article/158/Radiators/2572/American-Radiators-1937
It pays to wander off the Wall.Baltimore, MD, USA
Consulting0 -
I have that resource but I have never seen that Element? Do we just use the 4" Cabinet ratings.0 -
I bet
the name is actually "AERO" rather than "ARCO". If so, these were made by the National Radiator Co., and yours is 35 square feet.Baltimore, MD, USA
Consulting0 -
Aero Convector from National Radiator Company?
Steamhead, you seem to be quite good at identifying Radiator EDRs. I've already used your information from another post to identify a one pipe steam ceiling radiator that we have in our house. I am now trying to get the EDR rating for one last radiator.
The radiator looks the same as the one in this thread. I have confirmed it says Aero Convector on the left hand side of the radiator. I cannot see the entire radiator so I have been unable to find any other words by which to identify the radiator. That said, I suspect it was manufactured by National Radiator Company. It has 24 sections book-ended on each side. Not certain if I should include the book-ends in the EDR calc. The first picture below shows one of the "book-ends" next to the air vent. It has fins on one side. The center sections each have fins on both sides. So..is this 24, 25 or 26 sections?
What would you figure for it's EDR?
It is a very cool radiator!
Thanks for your help.0 -
Dimensions...
I forgot to specify that the radiator is 18"high, 50' long and about 3 to 3.5" front to back.0 -
So I have the same old radiators in my home is there a way to adjust how much heat radiates off a unit? I have a whole lot of these things and some heat way better than others. Some have the knobs in the front cover some do not.
- 128 Chimneys & Flues
