removing in-wall steam radiator
cs2eye
Member Posts: 1
we are replacing the floor under this radiator. with the connection shown, will i be able to remove the radiator w/out opening the wall to the left of it? as you may be able to see, the opening on the wall is as wide as radiator w/out any wiggle room. the picture shows the opening moulding against the radiator!
(sorry apparently i took the photo upsidedown!)
thanks, cs
thanks, cs
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
