Lochinvar 55-DHW Options
ced48
Member Posts: 469
I plan on installing a Lochinvar 55 in a small closet, about 3 feet wide, and 2 feet deep. I must keep the DHW in this space as well. Demand is very light, 2 showers in the morning, and a little water for hand washing dishes, ect. I think I can squeeze in a 20 gallon HTP Superstor, and probably a 30 gallon. Are there other, better choices?
Turbomax?
If your worried about domestic hot water running out you might want to look at the Tubomax reverse indirect. The Turbomax 23 is only 49" high and 18" deep but will keep them with enough hot water to not worry about a callback.
Just an idea.
Rob0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
