Old video
ChrisJ
ChrisJ Member Posts: 17,048
I took this video on a night we saw 4F outside.  First time my system ever saw a night near this cold since I installed the boiler.
This was near the end of a cycle and I was maintaining 70F.  Hopefully this link will work for anyone.
<a href="https://www.facebook.com/photo.php?v=10151563743461253&l=1858400375853162336">https://www.facebook.com/photo.php?v=10151563743461253&l=1858400375853162336</a>
Another good video I took during a 9 degree recovery.  Its a shame because the camera ran out of memory just before the pressuretrol tripped.  Once it fired the burner back up the system reached its temperature and shut down.
<a href="https://www.facebook.com/photo.php?v=10150738669961253&l=4207134340361352597">https://www.facebook.com/photo.php?v=10150738669961253&l=4207134340361352597]https://www.facebook.com/photo.php?v=10150738669961253&l=4207134340361352597]https://www.facebook.com/photo.php?v=10150738669961253&l=4207134340361352597</a>
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    Great!
    Thanks for the videos!  What a great indicator that your boiler is perfectly sized for your system!  It could not be much better.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • ChrisJ
    Thank you
    for watching.
    I'm glad it all worked out especially since I was originally going for an EG-40 and decided to go to the EG-45 instead.
    I have to admit, I'm depressed its spring and the heating season is almost over.
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,917
    Buck up there.
    No one said you have to stop running your boiler just because it's getting warmer outside. Just turn the thermostat up a few degrees and sit around the house in a speedo, or go outside and jump through the lawn sprinkler. I never suspected you were anything but a hard core steamophile. :-P
  • ChrisJ
    Speedo
    No one needs or wants to see me in a speedo. :)
