How connect steam Cast Iron baseboard around 90 degree corner?
bruce_21
Member Posts: 246
I got some special fittings to go with the cast iron baseboard to connect two sections in a corner one for top tappings and on for bottom ones. They are flexy gizmos that look like they will reduce the size from 3/4 to maybe 1/2 inside. Will this cause a problem by making a dam and keeping condensate trapped in the first section of the baseboard unable to get to the return drain at the end of the second section?
Corner mounted baseboard radiators
Yes you will have a problem using anything other than regulet straight iron pipe, angled for drainage.
If this is an addition of one more baseboard, will the riser/supply be of sufficient size to supply enough steam for both?--NBC0 -
What about expansion/contraction?
This is a replacement situation. 16 feet of cast iron base board now fed by one pipe steam system. Supply is 1 and 1/2 inch steel almost flat run out from main line. This run out also supplies another small rad on the floor above. The existing base board has 3 cracks, 2 at the far end and another at a point just before the inside corner. Per Dan's book TLAOSH I plan to add a 3/4 or 1 inch (which is best?) return line from the far end of the baseboard back to the wet return. I'm wondering why this baseboard cracked in the first place. The two 8 foot pieces are joined together with 3/4 copper male adapters and 90's. How much will this baseboard expand? It is held by the exterior wall one one end and I can't see the pipe on the supply end because it comes horizontally out of a cabinet. Thanks for your help!0 -
copper expands
Roughly 50% more than iron does with heat.0 -
will
a 3/4 blk union fit inside the trim?0 -
Use
2- 3/4" radiator union elbowsand 2-close nipples0
