Oops.. Any way to turn a 408J1033 into a 408J1017?
boilerop
Member Posts: 4
So I made a mistake when ordering and I'm not sure if I can return this or not. Before I order the correct one is there any advice on how I can make this function the same way as a 1017?
It all depends on the switch.
The 1009 and 1017 have SPDT switches, while the 1025 and 1033 have SPST switches, but sometimes they use the same switch, because it's cheaper to do so, but sometimes the SPST switch is actually the SPDT switch with the "B" terminal removed.
Bottom line: If the switch has a "B" terminal, you're in luck. They are both 0-4 psi Vaporstats.Just another DIYer | King of Prussia, PA
1983(?) Peerless G-561-W-S | 3" drop header, CG400-1090, VXT-240
