Radiator refinishing...
Mark_125
Member Posts: 56
Fellow Steamheads,
I've decided that once the heating season comes to an end I would like to get my radiators re-finished to remove any traces of lead paint that might be on them. Now this may sound like a dumb question, but should I be concerned that once all the radiators are disconnected on the second floor that the risers and the main might drop due to the lack of support from the radiators above?
Thanks,
Mark
Thanks,
Mark
if
your worried about it, what u can do is put split ring hangers on the pipe where it comes thru the floor, that is the cheapest way, they also make riser clamps, they r a little more expensive but would prolly opt for the split ring hangers.0 -
can you stick a block of wood under the neck of the valve
to keep it supported0 -
I agree
pipekings method is the best bet0 -
Block the valve
That's what I would do, if there is no one around to hurt their toes.0 -
Just a 2x4 ?
Are you just talking about regular 2x lumber?0 -
Start in the basement.
Sounds like a good time to evaluate how well your mains are suspended in the basement. In my limited experience this is frequently lacking. Recently repaired a leaking flange union in our church's main caused by inadequate main support.
Good support in the basement keeps stress off the pipes, help to maintain proper pitch, etc. etc. With adequate support at the mains I wouldn't worry much about support at the radiators, though the suggestions already mentioned are good belt-and-suspenders measures.
Good luck.
Patrick0
- 119 Chimneys & Flues
- 114 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
