Owner
Kh114
Kh114 Member Posts: 3
Can you run a loop of rdiant off a baxi combo boiler that has 40ft of baseboard.
  • heatpro02920
    heatpro02920 Member Posts: 991
    Loop of radiant?
    Im not sure exactly what you are trying to do, anything is possible... Can you give a little more info???
    Are you concerned with getting the low temp radiant needs out of a boiler setup to make high temp water for baseboard?
