New steam boiler has unwanted vacuum
JFeathers
Member Posts: 1
I just replaced a Weil Mclain LGB-7 that had 5 cracked water jackets. Replaced with the exact same gas steam boiler. System has pressure-trol controls. Upon startup the system will not gain any pressure. Has only vacuum. Neither I nor my company has experienced this before. From the research I have done, at some point in history this building had a Bromell system and was coal fired. The steam venters that are installed are 1A and there are 3 of them throughout the building. Any help or suggestions would be greatly appreciated.
There's got to be more to this.
Is there a vacuum pump? Are you getting any steam out of the boiler? Is this a one-pipe or two-pipe system?
What kind of vents are you talking about? Hoffman 1As are angled 1/8" radiator vents. Are you saying these are the only vents in the system? Where are they located?
It might help if you could post some pictures.Just another DIYer | King of Prussia, PA
Broomell system
http://www.heatinghelp.com/files/articles/1383/54.pdf is worth a read. Are the original trapped union elbows still there?
I'd love to see that "Combined receiver, Draft-regulator, Gauge, and Relief Valve" in person.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
