Heat in one zone, not both
Lost power due to Nemo. Power restored. Heat upstairs, not downstairs. Brand new boiler and thermostats (digital). Forced air, floorboard heating. Thermostat clicks, but no airflow to match setting. Any advice?
  • Maybe something ez
    So its a furnace not coming on? Or a boiler feeding a hydro air, Im kind of confused what you have..
    Try.. Shutting service switch off, turn thermostat all the way down, make sure circuit breaker is on, turn furnace on, wait a couple minutes and then turn the thermostat up past the room temp...
    If that doesnt work, let me know what equipment you have, and it may be as simple as a fuse...
  • Techman
    Techman Posts: 2,143
    Forced air unit
    At the t'stat put the "fan" switch in the "on" position. If fan comes on then all is well w/ the air handler.And the problem is more than likely w/ the hot water side of the system.
