New York State building code for furnace venting?
Toller
Member Posts: 9
The inlet on my 2006 Trane furnace froze up. I found that the
contractor installed the vent too close to the inlet, and didn't make
the vent long enough; per Trane's installation instructions. He fixed
the second and sorta fixed the first.
However I also found that
the vent was 11" from an inside corner and 4" from an overhead deck. I
am told that is grossly inadequate, but Trane simply says to follow
local code on those.
I checked with the local building
inspector. He says that the only applicable local code is the NYS
building code. In 2007 that was changed to require vents to be 4' from
inside corners; previous to that it wasn't mentioned. He finds nothing
on distance from something overhead.
Is that correct? Was the contractor in compliance in 2006? I am hoping someone might be familiar with this.
The
inspector is overworked and admits he doesn't know as much as he would
like about furnaces as he would like; so I wonder if he is missing
something.
The
something.
- 87.8K THE MAIN WALL
- 130 Chimneys & Flues
