York High efficiency Furnace leaking water/condensate.
Xephyron
Member Posts: 1
in Gas Heating
It's not leaking from the condensate pump, but it seems to be leaking from the pipe that goes into the pump inside the furnace.
Refer to the pictures here
<a href="http://s1304.beta.photobucket.com/user/wly3298456/media/IMG_0008_zpsa1503c5e.jpg.html?sort=3&o=0">http://s1304.beta.photobucket.com/user/wly3298456/media/IMG_0008_zpsa1503c5e.jpg.html?sort=3&o=0</a>
Any ideas on what the problem might be?
Thanks!
Read more: <a href="http://www.doityourself.com/forum/gas-oil-home-heating-furnaces/487971-york-high-efficiency-furnace-leaking-water-condensate.html#ixzz2K4QXgWB9">http://www.doityourself.com/forum/gas-oil-home-heating-furnaces/487971-york-high-efficiency-furnace-leaking-water-condensate.html#ixzz2K4QXgWB9</a>
Thanks!
York
York is notorious for having condensate leaks. Best case scenario, it's just a loose pipe, and not the condensate collector in the furnace.0
- 128 Chimneys & Flues
