Sizing an Indirect Water Heater
ced48
Member Posts: 469
I am trying to replace the heating/DHW in a small house, 30K heat loss. I think I am going to possibly use the Cadet 40, 32 net modcon boiler. The hot water demand is small, two morning showers, closely spaced, and a few dishes washed, ect. Should a 20 gallon unit work?
run the numbers
Something like http://rightspec.bradfordwhite.com/Sizing/Residential.aspx will tell you the answer.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
