How To Add Radiator to Current Hot Water System
netguy7
netguy7 Member Posts: 2
Hi.  We have a hot water heating system in our house.  I am attempting to
install an old cast iron radiator into the bathroom.  There used to be a large
one in the room but the previous owner removed and replaced it with a small
baseboard type that does not provide nearly enough heat for the size of the
room.  So I have two pipes coming up through the floor that I plan to tap into
using the vent caps to access them as I plan to leave the existing baseboard
heater in place.  The fittings I plan to access are pointing straight up  (the
baseboard is connected from the side of each of the cone type fittings on the
top of each pipe).
One of the vent fittings appears to be 3/4" and the
other 1/2".  Would it be reasonable to assume that the 3/4 fitting is the supply
line or ?  Short of waiting till the system cools and then starting it again and
placing my hands on each pipe to see which one warms first, how can I determine
which side is the supply side?  Does it even matter?
The radiator is 32"
tall - 8 ribs long and 6 ribs wide.  The fittings on the bottom of each narrow
side of the radiator had been used previously in its original application.  The
vent is on the top of one side.  Should I place the supply line into the side
with the vent above and use the shutoff valve on this side too or ?
I
plan to use 3/4" copper pipe and fittings even though the radiators original
fittings are 1/2" on the outgoing side of the fitting (3/4 on the ingoing
side).  Should I connect to the original galvanized steel female fittings from
the radiator with copper male fittings or use something else to connect the
copper pipes?  Should I just use plumbers tape or something else on the
threads?  Any other tips or concerns about this?
Finally, I plan to
install shutoff valves on each line that have a bleeder and that seal with
compression fittings (that screw on and off) so that I can easily remove the
radiator in the summer months and easily reinstall it again before winter if I
want to.  Any concerns about this?
Thanks Much!
