Richardson radiator problem found
Fizz
Fizz Member Posts: 555
but may not be worth fixing.  The lateral that radiator is supplied by, as well as 4 other radiators, is a 3/4" pipe, and Richardson minimal supply pipe other than riser is 11/4 for up to 150 sq ft radiation.  The attached radiation to current piping is 141 sf.  Is this assumption correct, and is it worth correcting?
