diverter tee
hey everyone im having a problem with a radiator in a diverter tee system....i was called to install all new radiators in a home ....previous company took all radiation out of home....customer said previous radiators foze up and cracked....company never came back....i installed SUNRAD radiators in the home.....everything is heating well except one.....the radiator not heating is obviously a flow problem not air....the supply and return off the main were changed previously ....do not know why.....all diverter tees in system are venturi tees....except for this one it just says TACO on it.....how would i fix this flow problem ....ive heard of putting 2 diverter tees on the radiator one on the supply and one on the return would that work.....and radiator is directly above main 2-3 feet to the right..
paul s
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
  • JStar
    JStar Posts: 2,752
    Rad
    How big is the rad? How far apart are the tees?
  • Paul S_3
    Paul S_3 Posts: 1,297
    rad
    12 section radiator....i think 24 inches across...and the tee's i think 2 feet apart....i will go back tomorrow.....customer called me and told me what was going on i did the install last weekend.....the radiator thats not heating is off the loop that looked changed recently
    347-692-4777
    ASMHVACNYC.COM
