Burnham Alliance SL 35 Drain leak
Just as I suspected that it would the flimsy plastic drain on the Burnam Alliance Sl a rebaged Vaughn Top performer has started to leak. Can I unscrew it and replace with a normal drain. I cant figure out if i can remove it and its just a normal npt thread in the tank shell itself. Thanks in advance!
It is 3/4" npt...
you might try a std hose cap 1st before doing all that draining.0 -
YUP
3/4 npt, but u might need a nipple and a fml drain if it is recessed in from the jacket.0 -
A cap is on there now
Unfortunately it strarted to leak through the packing nut as well. The person who came up with a plastic drain on a not so cheap tank ..... Thanks, I'll drain it and put a ball type drain.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
