Locating Spot For Low Pressure Gauge
TomH42
Member Posts: 43
Now that my system seems to be running at the low pressure that is recommended here, the main 0-30 psi gauge has not been registering. I am interested in installing a low pressure gauge. Here are pictures of the furnace and return vents.
In another thread I thought I saw a low pressure gauge that was located on an antler with the main line vent. In my case it would be added near the Gorton #2. Is it acceptable to add a low pressure gauge there?
If the gauge has to be added near the pressuretrol, would there be a reasonably easy way to do it?
Thanks.
Thanks.
This is what...
I have done. It looks like we have a similar layout. I am in the process of changing the pigtail so that I can make removal easier.
http://www.heatinghelp.com/forum-thread/144679/Pigtail-modification
http://www.heatinghelp.com/forum-thread/144716/Pigtail0
- 114 Geothermal
