Daily flameouts in our Building
Alklip
Member Posts: 1
we are experiencing daily flame-outs of our burner when set to gas and weekly
flame-outs when set to oil. The problem became this severe when we modulated the
burner, although we have always had monthly flame-outs.
we have a Weil McLain C3-G0-25B boiler with a Powerflame WCR3-GO-25B dual
oil/gas burner
the boiler is over-sized for our building and that led to heating and efficiency
issues and is the reason we undertook the modulation
the flame-outs became this severe when we recently modulated it to Lo Hi Lo
operation with a Honeywell 190400 #V4062A-1008 gas valve, and added a Honeywell
0-4 PSI Vaporstat #L408J-1017 to the control-tree (and connected it to the
burner). It's set to cut-out to 1¼ PSI, and the differential to 12 Oz/In².
we are in discussions with Powerflame, but so far the flame-out problem is
unresolved
oil/gas burner
unresolved
flameouts
i am surprised that you have left such a potentially dangerous situation continue so long. who is working on this problem? it will probably need someone with a combustion tester to get to the root of this.--nbc0 -
The burner is not tuned properly
you need a qualified person to tune it in.Cost is what you spend , value is what you get.
cell # 413-841-6726
Tuned:
Like a Power Flame trained Rep.0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
