Furnace startup issue - video included
Chiheaterissue
Member Posts: 1
<a href="https://www.youtube.com/watch?v=rftRPNrScm0">https://www.youtube.com/watch?v=rftRPNrScm0</a>
Above is the video clip of my furnace starting up (issue at 1:50 into the clip), I'm worried it will give out soon and it's freezing around here. Please let me know what I should tell a professional the issue is. Thanks for the assistance and advice.
Lennox Has a
Similar furnace and I had a similar issue that turn out to be a bad burner.0 -
Problems
Could be a bad burner, also could be a mixture problem. Remove the intake pipe ( 2 inch PVC pipe ) and see if there are any leaves, bees nests, dead animals.0 -
I wouldn't run it
That's a Rheem "Drum" (the r is silent) and the were nothing but trouble. First, that's not the proper ignitor. So who knows how long it is. The factory ignitor has about 6" of ceramic, then the ignitor. That burner has a cover over it full of holes. They like to rust out which could be causing this. The heat exchanger itself liked to rust or split open. Personally I'd get it out of there QUICK, but if you can't, find a Rheem dealer with an old tech who was around in 1990 when those lemons were out. First step is a 62-22669-92 ignitor, check the burner, check the heat exchanger, check the PVC pipes...0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
