Anti- freeze test strips
ddr
Member Posts: 14
We currently use Hercules test strips for testing antifreeze. Do these test strips work effectively with other manufactures products or do we need different test strips for each available product? I'm guessing the AL transfer fluid would be different. We also have used a pH meter in the past, but just looking for a reliable and effective way of determining the condition of hydronic antifreeze.
Refractometer
We use refractometer to test freeze protection and pool water ph test kits which work rally well on anyone's product
Good luck
JimThere was an error rendering this rich post.
Test Strips:
Where I work, in an isolated area, there are only two supply houses. One sells Hercules and the test strips that go with them. The other one sells something in a blue 5 gallon pail. I buy from them. I bought a Misco Refractometer and have used that. I worried because I was told that nothing but the strips worked on Hercules. And that you couldn't mix the two. Years ago, I dropped my Refractometer and the prisms went out of alignment. I called Misco and it was an easy fix. Send them the old one and they would fix it and recalibrate it. So, I asked if there was an instrument that you could use other than test strips on Hercules. The woman laughed and told me that Hercules buys refractometers from them for testing solutions in manufacturing
So, get yourself a Refractometer. They're a lot easier than test strips.0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
