Furnace not working, 20 degrees outside
hrolsons
Member Posts: 1
in Gas Heating
Our furnace is not working. We have a company coming out tomorrow morning but it's 20 degrees and I'm afraid the pipes will freeze. I've changed a furnace motor before.
The furnace comes on and spins and then after a few minutes makes a noise and the motor stops. Control board flashes 3 times. It is a Rheem furnace.
Do I need a new motor? Any idea where to get one in Denver?
Thank You,
T. Derek Olson
Thank You,
T. Derek Olson
some where on the bottom door
you will find a chart to tell you what the blinks mean . likely the inducer motor is shutting down and opening the pres. switch . see what the blinks are cluing for0
- 128 Chimneys & Flues
