Steam master tablets
Steve_210
Steve_210 Member Posts: 664
What is the general consensus on using these
I just started to use them they're very easy and convenient
I know there have been previous posts just can't seem to find them
Has anybody any experience with prolonged use, Any problems etc.
Thanks guys
  • ChrisJ
    ChrisJ Member Posts: 17,391
    edited January 2013
    Hopefully
    Gerry Gill will respond as he is the one that got me hooked on them.The only thing I have seen mentioned and its not directly related to steamaster tablets is a higher PH can errode the gauge glass.  Personally I'm not concerned as I'd rather replace a $1 peice of glass than my block and I keep my PH around 9.  I'm going to order a few as well as a cutter with my next order from pexsupply.com
  • Steve_210
    Thanks Chris
    I would also not be concerned About a Sight glass
    But A well-known boiler manufacture do use gaskets between their sections, does the PH
    Levell have an effect on these
  • ChrisJ
    gaskets
    My boiler is a Weil-Mclain which has gaskets. As far as I know a high PH of even 11+ wouldn't bother the gaskets but that would cause foaming issues.
  • gerry gill
    gerry gill Member Posts: 3,084
    I like them,
    but i also like Rhomar and TSP..
    gwgillplumbingandheating.com
  • Steve_210
    Thanks guys
    That's what I needed to know
