hot water boiler noise, poping
tom k_5
Member Posts: 12
I HAVE A 25 YEAR OLD HOT WATER BOILER. ITS MAKING POPING NOISES, LIKE SHOES IN A DRYER. WE THINK ITS MINERALS ECT. LIKE A HOT WATER HEATER. CAN IT BE FLUSHED AND A CLEANER SENT THRU SYSTEM? THANKS TOM
Shoes in a dryer
There should be very few calcium deposits in your boiler, as it is a closed system, unless there is a leak which the valve automatically adds water to compensate.
What make is this boiler? What has changed since the shoes began to make noise?--NBC0 -
Boiler noise
Thanks for reply. Its a utica. Last year system was opened to replace a section of baseboard. And thats it. I agree its a closed system. There are no leaks in system. No loops under ground. Should i drain it and add something0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
