wheezing Weil Mclain
Matthew Grallert
Member Posts: 109
Hi folks
I seem to recall a tread on the topic of a wheezing boiler. I have a customer complaining of a wheezing sound coming from his boiler while the burner is on and for a short period after if shuts off. I've visited and did hear it. it is coming from the boiler and telegraphing through the piping. Its not a constant wheeze but repeated and regularly during the run cycle and continuing for a short time (maybe 30 seconds) after the burner shuts off.
This is a water boiler with an indirect and one heating zone. Is there a solution to this?
thanks for taking the time to read and contemplate.
Peace
Matthew
Peace
Matthew
if it's
a slight whistle sound also, I would remove the top, and look for leaks where the "O" ring is between the sections. Many times you would never know it is leaking0 -
thanks for the reply billwocase. That occurred to me as I've heard the sound before but in boilers maintaining a temp with a tankless. Although a few years ago the Mr. had a cracked radiator which was solved with a boiler seal liquid. Ill have to look for a leak at a gasket. Thanks again
M0 -
I would say
change the extrol tank. If there is sealer in it, or was at one time, it will be a problem like this0 -
sediment
You have sediment in the bottom of the heat exchanger. When the burner is on it boils the water between the sediment and the cast iron bottom of the heat exchanger. Increase the wate pressure up to 25 PSI and see if it goes away. ( not the solution - only a means of diagnosis)0 -
I'm leaning towards crud in the boiler. I've replace the ex tank and checked it's pressure.
I'm also leaning towards the possibility that the house was built on an Indian burial ground do to some other very odd occurrences.
M0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
