Tekmar 403 halp please!!
Timco
Timco Member Posts: 3,040
Hey all....
I installed a 403 on a RBI this past year. If I bump
my mix target to 170*, the boiler target still says 150* and will not
rise to meet the mix. period. I turned off the boiler min and my boiler
design is 180*. Outdoor design is 15*. Whatever I change, I cannot make
this boiler fire up to 180* and get my mix over about 135*. Delta t is
about 10* or less. I need more heat but just can't seem to get it.
Ideas?
Thanks,  happy new year,  Tim
  • nicholas bonham-carter
    Outdoor reset problem?
    Is there some outdoor reset in this problem?--NBC
  • Timco
    403
    Has a reset feature. It's outdoor design temp is 15* so it allows the most at 15* instead of 5* or 10*. How is it possible for the mix design to be higher than the boiler design??? Shouldn't the boiler design be set based on what the mix design and outdoor temps are??
  • tim smith
    tim smith Member Posts: 2,935
    Re: Tekmar
    Tim, call  Tekmar support this am, they are really helpful and will get you through it the quickest.  Good luck
