High Capacity Main Air Vent
New_to_Steam
Member Posts: 4
I'm having issues with radiators not heating up and, I suspect the problem lies with the main air vents. There are two of them: Durst No. 4's with a 3/4" thread. One of them gets hot but, no air is being expelled. The other is completely cold. Can anyone recommend a good, high capacity main air vent? FYI, the cut-in on my boiler is 1 lb and the cut-out is 2.5 lbs. I recently replaced most of the radiator vents with Hoffman 1A's.
Vents
Gorton2. It's the highest capacity, and highest quality main vent.
You should also lower your pressure to a cut in of 0.5 and cut out of 1.50 -
Thanks so much!0 -
How Long
are your steam mains, and what pipe size? This tells us how much air is in each main that we have to get rid of.
Gorton #2 is the biggest vent made today, but do you really need it?All Steamed Up, Inc.
Consulting0 -
Main Line Specs
One line is 37' from the boiler, the other is 27'. The pipes are 2.5 inches in diameter.0 -
Definitely Gorton #2 territory
on the longer main. For the shorter one, I'd use two Gorton #1 vents. This should result in steam reaching the ends of both mains at about the same time.All Steamed Up, Inc.
Consulting0 -
I'll give that a shot.
Thanks for your help!0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
